how to create a simple graph labwindows 5.5.1
I am new in LabWindows 5.5.1 and have no idea how to create a simple idea.  My program gets data regualary from a scale. The measured values are controlled(compared with min and max value) and saved.
Now I want to display the last 36 values in combination with min and max values, where I can have a general view. What I know is to store my data in an array. Not more.
Is there a simple tutorial or can anybody help me?
Any help would be appreciated.
(2,999 Views)
Hi setirli,
I gues I did not realy understand what you want to do. Let me try to summerize. You want to acquire a signal from an data acquisition device and store the values in an array with 36 elements, then you want to compare these data with a min and mx value. You also want to present the data in one display? Is this right, correct me if I'm wrong.
Regards
TomBaum
(2,949 Views)
