LabWindows/CVI
how to lock the current tab
Hi all,
  I have placed a tab control to the application, in one tab panel I am running a heavy code which takes couple minutes to be done. During the code running time, I want to lock the current tab so it can't switch to different tab. Is that any way to do that in CVI? Thanks.
(3,613 Views)
Accepted by dragondriver
Hi dragondriver,
  I don't think you can lock a tab, but you could programatically dim all the other tabs on the same event that starts your heavy processing and then undim them one it finished.
Hope this helps,
Bogdan
(3,592 Views)
