how to programme the freeze button of an oscilloscope
i want to programme the freeze button of my oscilloscope to stop the transmitting signals from moving...how do i go abt doing it? i also want to move the waveform after stopping it...how can i programme the button to perform these two requirements?
(3,209 Views)
Paul,
The specifics will depend on the implementation that you have. But an idea is to have an if statement arround the function that plots the data; this way you may be still acquiring the data but you will not be updating the graph; this will give you the effect of freezeing the signal.
To move the waveform you can use the functions to manipulate the axis; by changing the lower and uper limit on the graph you can pan and/or zoom the waveform; take a look at the functions:
GetAxisRange()
SetAxisRange()
GetAxisScalingMode()
SetAxisScalingMode()
I hope this can give you some ideas to start with.
Juan Carlos
N.I.
(3,209 Views)
