LabWindows/CVI
how to set to factory reset for sbRIO-9629
I would like to reset my sBRIO-9629 to factory reset.
It's very appreciated if you could tell me.
What is the default IP address?
best regards.
(2,951 Views)
[additional information]
NI MAX can't recognize my sbRIO-9629. Therefore, I would like to reset it with a physical way without S/W.
(2,918 Views)
https://www.apexwaves.com/pdf/manuals/sbRIO-9609/CompactRIO-Single-Board-Controller-with-DAQmx-Hardw...
To put it into safe mode you need to push the reset button for more than 5 seconds. Refer to Troubleshooting the Controller on page 58 and 59 about how to reset it to factory default settings. You should be able to connect it with an USB cable afterwards to do the initial setup.
Rolf Kalbermatter  My Blog
(2,856 Views)
Dear Rolf,
Thank you for your reply. My sbRIO could recognize with the other ethernet port (my sbRIO has 2 ethernet ports.) via NI MAX. However, your suggestion is beneficial, therefore, I'll try next time.
Thank you.
Kay
(2,848 Views)
