imaq vision function reference
Hello All,
I am new to Lab Windows/CVI and am using the imaq vision library.
Could anyone tell me where I can find the IMAQ Vision function reference? I have found a function reference manual at Start--> National Instruments --> Vision--> Documentation. But, all the functions described in this document are starting with img******(). I was looking for functions beginning with imaq****().
I am sorry as it might be a stupid question but any help would be appreciated.
Cheers,
(4,730 Views)
Hello Harmonium,
i think what you search is under Start --> National Instruments --> Vision --> Documentation --> NI-IMAQ IO
In this directory you found the documentation for the imaq**** functions.
C:\Programme\National Instruments\NI-IMAQ IO\Docs
There are three librarys the NI-IMAQ I/O, NI-IMAQ Librarys and the NI-IMAQdx. If you can please use the NI-IMAQdx library,
because its the newest for doing aquisition. The documentation can be found here
C:\Programme\National Instruments\NI-IMAQdx\Docs
best regards
Alexander
(4,716 Views)
Accepted by Harmonium
Thanks Alex,
I found the document 🙂
(4,713 Views)
Hi,I am facing problem in importing niimaqdx.dll in visual basic 2008 .all those function which comes under "niimaqdx.functions" are not being refleced.please help.
(4,244 Views)
You suggest using the NI-IMAQdx, because it's the newest version. How do I control whether I'm using NI-IMAQ or NI-IMAQdx?
(4,206 Views)
Hello DukeTom,
you can see it in the name of the functions, if you work with IMAQ or IMAQdx.
There are are two different libraries inside CVI.
best regards
Alexander
(4,183 Views)
