LabWindows/CVI
increment or decrement arrow clicked on the numeric control?
is there a way to tell which arrow has been clicked by the user?
thanks
(3,344 Views)
Accepted by topic author sinnas
Only indirectly:
1) Read the value of the control
2) If the event EVENT_VAL_CHANGED occurred, read the value of the control again
3) The new value should be old_value +/- increment_value; from this change it is possible to derive the sign of the increment, i.e. positive or negative; this you can translate to up or down Smiley Happy
Hth,
Wolfgang
(3,341 Views)
oh ok i thought i was missing a simpler way to do it.. Thank you wolfgang!
(3,335 Views)
You're welcome.
Note however that the sketch of this indirect method is simplified because it may happen that an event EVENT_VAL_CHANGED is triggered while the numeric value has not changed at all! Hence you might consider supporting my suggestion for an improved behaviour of this event here.
(3,329 Views)
