LabWindows/CVI
localize japanese cvi
Is it possible to use the localui.fp to localize in japanese language ?.
If yes, what is the best way to do it ?. Must I install all CVI on japanese system ?
What about the lwl files ?.It seems impossible to add them into the distribution kit because the're text file and the developpement systme is french !
Thank you for any advice
(2,955 Views)
Pierre,
The main problem here is that french is a single byte language, and japanese is a multybyte language. In order to localize your application you will need to install a japanase version of Windows and localize your panels there.
Here is a very good document with a bunch of links, please take a look at them and let me know if you have further questions.
Using LabWindows/CVI Localization Utility with Single/Multiple Byte Languages
Juan Carlos
N.I.
(2,955 Views)
