mysql database with cvi
hello
i need an exemple of how to connect to mysql database and how to insert data ,
(3,819 Views)
Hi corail77,
Have you checked the LabWindows/CVI SQL Toolkit Reference Manual?
There are some examples there. A code snippet for inserting a record can be found in page 3-6.
Hope this helps!
Saki K.
(3,757 Views)
I suggest you search the forums with the search terms CVI mySQL . You will find lots of helpful info from previous users!
(3,707 Views)
