older LW UI editor not compatible with Win2K
Require editing existing LW 2.3a code in Win2K or WinXP system. Need to emulate DOS box properly so as to fool DOS extender. Original environment was DOS 6.20 with EMM386. Error code in Win2K: DOS/16M [35]
(3,341 Views)
Hello
In CVI 6.0, if you open up a .c file, go to Options >> Translate LW DOS Program. You would need to have your CVI DOS project loaded up before you try this. This should help you in converting your older UIR to the newer one that should work with CVI 6.0. CVI 5.x and above now only create 32 bit code.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,341 Views)
note however that the Options / Translate LW/DOS Program has disappeared in the latest version of CVI
(2,898 Views)
