Dear Bas,
Since there was a deadline for my application to be finished I created a workaround.
I used the F1 button to load up the typical html-help thing. Since the panels I
wanted to react on the F1 button all had a menu of there own as well,
I create a new menu item and add the F1 button there as a short-key.
This worked out just fine.
After all of this I heard a newer version of LabWindows has been releashed and
maybe the problem I had is gone with it, but I had no time to test it.
The problem I had then and now is that I used the panels of LabWindows itself
to create the panels and set the callback events on some buttons for them.
This means that posting code is not much of a use I suppose, since
all I did was creating one parent panel with a callback function for the F1 key and
on this panel I loaded a child panel with a callback function for the F1 key.
I wished I could have been more of a help here, but I'm sorry to say
I haven't had the time to test my case under the new LabWindows and
investigate it a little a more.
Since nobody seems to run in the problem I had, I'm still wondering to maybe
I messed up somewhere.
Kind regards,
Bas
([dutch] Ps. Leuk om hier een naamgenoot te vinden
🙂 [/dutch] )
