possibility to display a 360° Control
I'd like to display a circular control for the complete 360°. Is there a possibility ?
The numeric dial or gauge controls leave some degrees on the bottom .. so that the needle cannot show all degree positions.
(3,528 Views)
Would something like this attachment be suitable?
JR
(3,515 Views)
yes - exactly. how do i get this ?
thank you
btw. is it possible to configure the colors of the needle, or to define segments with different colors ?
(3,512 Views)
Its just a standard numeric gauge, with the start/end points set to the same position in the control editor.
You can change the colour of the needle at design time in the control editor - click on the paintbrush icon in the Quick Edit window then right-click with the brush over the needle. I don't think there is a direct way to show segments in different colours, but by making the control background transparant you could draw it over the top of a canvas/bitmap which had the colour scheme you want.
JR
(3,508 Views)
i see, thats an idea. Thank you.
(3,504 Views)
