ramp analysis library function not available with CVI 8?
After upgrading to Labwindows CVI 8 (from CVI 7), the Ramp function does not exist in the Analysis library. What happened to it? Is there an equivalant function somewhere that I can use?
(3,616 Views)
Hi kmagas,
The Ramp function is part of the Advanced Analysis Library which is part of the LabWindows/CVI Full Development System package. My guess is that in CVI 7.1 you had the Full Development System and now in CVI 8 you just have the Base package.  Thus you don't have the Ramp function.  I would contact your local sales representative to see if you got the wrong package or what.
Best Regards,
Jonathan N.
(3,607 Views)
thanks, I do have the base version but apparently I will need to upgrade.
(3,596 Views)
Hi
Is it posible (technicaly and by licence) to reuse the analysis library
of the 7.1 Full with the 8 Base?
Babak
(3,587 Views)
Hi Babak,
While this is theoretically possible and legally allowable, it is neither supported nor recommended.
(3,553 Views)
