remove/insert section
hello,
I have the following problem.
1) if the button "delete" is pressed it should delete the last section from the IniFile
2) if the button "insert" is pressed it should insert an section between 2 phases in the IniFile
I have tried it already with Ini_RemoveSection with 1), however, this does not work.
the section was build
[SECTION_1]
Item1
Item2
Item3
can somebody say to me like me the both buttons must program?
(5,261 Views)
Hello Axinia, you can find answers to most of your questions regarding ini files looking at the following example project installed on your disk: <cviSampleDir>\toolbox\ini.cws. (The folder were examples are stored can be located by looking at "Explore examples" option in CVI welcome page).
What you may need additionally is  how to locate a particular section to delete it, since you need to delete the last one. You can accomplish it by using:
index = Ini_NumberOfSections (handle);
Ini_NthSectionName (handle, index, sectionName);
Ini_RemoveSection (handle, sectionName);
this code locates the last section in the in-memory copy of the ini file, next retrieves its name and deletes it. After writing the IniText object to disk the section will be removed from the file too.
What do you observe when using Ini_RemoveSection so that you claim it does not work properly? Do you receive any error in your application?
To insert a section, simply use the appropriate Ini_Putxxx with the proper section name and it will be automatically created, but keep in mind that the positin in the physical file cannot be predicte, since it is determined by the instrument (I suppose by the order of sections in the in-memory object, which can be different from your logical vay of considering your data.
(5,254 Views)
hello,
I have just programmed it like you have said it, but the last section is not deleted. there also comes no error.
can you or everybody tell me what is wrong?
int CVICALLBACK DeleteStepCallback (int panel, int control, int event, void *callbackData,int eventData1, int eventData2)
        int index;
        char *ptrSectionNumber;
        IniText tmpDeleteStep = 0;
        switch (event)
               case EVENT_COMMIT:
                          index = Ini_NumberOfSections( tmpDeleteStep );
                          Ini_NthSectionName( tmpDeleteStep, index, &ptrSectionNumber );
                          Ini_RemoveSection( tmpDeleteStep, ptrSectionNumber );
                      break;
      return 0;
(5,229 Views)
Well, for the first thing you are working on a local IniText handle (tmpDeleteStep) on which you haven't created the corresponding object with Ini_New () nor you have loaded it from a file with Ini_ReadFromFile.
Additionally, you are not trapping the error conditions, so you are not likely to have a break popup error if you have not set Run >> Break on >> Library errors menu item or you have used DisableBreakOnLibraryErrors () anywere in your code before that callback. If you set a breakpoint on Ini_NumberOfSections you should see that the return value is -65, meaning "A NULL pointer was passed when a non-NULL pointer was expected", since tmpDeleteStep is initialized to 0 in the declaration. To trap library errors you must examine the return value of the functions, possibly using nullChk and errChk macros defined in the Programmer's Toolbox.
In case you are interested in it, you can look at my contribution on run-time error checking, which analizes how to trap an error condition and warn the operator with relevant informations about it.
(5,225 Views)
hello,
the problem is the same. if i set breakpoints the values are correctly, but the the last section wasn't delete.
int CVICALLBACK DeleteStepCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
       int index;
       IniText tmpDeleteStep;
       switch (event)
              case EVENT_COMMIT:
                             tmpDeleteStep = Ini_New( 0 );
                             Ini_ReadFromFile( tmpDeleteStep, "c:\\My Documents\\LabWindows-CVI\\File.ini");
                          break;
         return 0;
(5,220 Views)
Accepted by Axinia
Try adding a Ini_WriteToFile at the end of the callback Smiley Wink
(5,218 Views)
a lot of many thanks for your help
you have helped me very much Smiley Happy
(5,214 Views)
