11-08-2016 12:21 AM
I'd like to creat a Command Button that the lable on it will be sqrt (square root) symbol.
I'll very appriciate your help with any direction if it's possible.
Thank you!
Eliran
Solved! Go to Solution.
11-08-2016
12:37 AM
- last edited on
08-13-2026
05:54 PM
by
Content Cleaner
Until the day when CVI will support Unicode I would use a picture button
11-08-2016 02:40 AM - edited 11-08-2016 02:41 AM
Or do the following:
11-08-2016 03:04 AM
Hi Roberto,
From some reason i'm getting (on the CVI) the "?" symbol instead of the sqrt symbol..
Do you know why?
11-08-2016 03:14 AM
for some reason I would NOT consider this a square root symbol... it is the first part of a square root...![]()
my idea of a square root is
11-08-2016 03:58 AM - edited 11-08-2016 03:59 AM
@Eliran
I don't know why you are getting the wrong symbol, maybe OS settings can influence the rendering of symbols. Which OS and language are you running on? Can you post a small UIR that shows the result you have gotten? I mean the actual .UIR file, not a screenshot.
@Wolfgang
While you are right in that that one is not the exact sqrt symbol, nevertheless it is a good approximation to that. I seems the user wants to create a small calculator inside its app: using the same font for all keys (including the sqrt) will give a good and uniform aspect to all of them: I suppose this is why that symbol is used in Windows calculator utility.
11-08-2016 04:52 AM
Hi Roberto,
I'm using Windows 7 (Hebrew language).
UIR file attached
11-08-2016 05:59 AM
Try with this UIR: I modified your adding a new button with the sqrt symbol, can you see it?
11-08-2016 01:02 PM
Thank you very much for your help!
