LabWindows/CVI
sqrt command button
I'd like to creat a Command Button that the lable on it will be sqrt (square root) symbol.
I'll very appriciate your help with any direction if it's possible.
Thank you!
Eliran
Message 1 of 9
(5,637 Views)
Until the day when CVI will support Unicode I would use a picture button
Message 2 of 9
(5,632 Views)
Accepted by EliranMar3005
Or do the following:
  • Open Charmap application, select Symbol font, locate the sqrt character, press Select and Copy
  • Create and edit a button on your panel, paste the text into Label field, then edit label attributes and select Symbol both as Character set and Font (in this order)
  • Enjoy the result Smiley Wink
Message 3 of 9
(5,612 Views)
Hi Roberto,
From some reason i'm getting (on the CVI) the "?" symbol instead of the sqrt symbol..
Do you know why?
Message 4 of 9
(5,607 Views)
for some reason I would NOT consider this a square root symbol... it is the first part of a square root...Smiley Wink
Message 5 of 9
(5,603 Views)
@Eliran
I don't know why you are getting the wrong symbol, maybe OS settings can influence the rendering of symbols. Which OS and language are you running on? Can you post a small UIR that shows the result you have gotten? I mean the actual .UIR file, not a screenshot.
@Wolfgang
While you are right in that that one is not the exact sqrt symbol, nevertheless it is a good approximation to that. I seems the user wants to create a small calculator inside its app: using the same font for all keys (including the sqrt) will give a good and uniform aspect to all of them: I suppose this is why that symbol is used in Windows calculator utility.
Message 6 of 9
(5,594 Views)
Hi Roberto,
I'm using Windows 7 (Hebrew language).
UIR file attached
Message 7 of 9
(5,588 Views)
Try with this UIR: I modified your adding a new button with the sqrt symbol, can you see it?
Message 8 of 9
(5,584 Views)
Thank you very much for your help!
Message 9 of 9
(5,567 Views)
