the control is not the type expected by the function.
hi!!
I'm creating a 3D graph with the library CW 3D graph 6.0.
I would like not to have an autoplot graph...and I'm searching how doing that...how can I put my values on the axis?
I tried with SetAxisScalingMode but it doesn't work...I have the error : the control is not the type expected by the function.
thanks
Adeline
(4,498 Views)
Accepted by adeline62
SetAxisScalingMode is intended for standard UI graphs, which CW 3D graph isn't. This ActiveX control has a completely different programming interface and needs the integration of 3DGrpahCtrl.fp into the project. The instrument driver makes available all functions related to the 3d graph control. You can set axes scales for example with CW3DGraphLib_CWAxis3DSetMinMax ()
(4,487 Views)
ok!!
thanks so much!!
Adeline
(4,485 Views)
