Lookout
CJ1m
I need to communicate whit a Omron PLC CJ1M. There is an ethernet card (etn-21) in the rack.
I have communicate whit Omron. They sent me a Modbus ethernet function block but I still dont have communication. There is a serial port on the PLC but Lookout don't support the CJ1M (it's not in the list of the PLC of the Omron driver).
Is there any other option then a OPC server?
(5,561 Views)
It looks like you can use the Modbus Ethernet protocol. Connect a cable to the Modbus Ethernet function block, and use the Modbus object in Lookout.
Ryan Shi
(5,543 Views)
