Lookout
Can I transfer data from lookout to microsoft sql server 2005/2008?
Can anybody please tell me the exact procedure to tranfer data directly from lookout to microsoft sql server 2005/2008?
-which data sources should I install (ODBC drivers)?
-what do I exactly enter in data source string and SQL fields in SQLexec or datatable object in lookout?
Robert
Message 1 of 39
(8,796 Views)
Robert,
As we discussed over the phone, please upload the .lks file and we can help here so everyone can learn as well.
I appreciate the contact and will do what I can to help,
Mike
Forshock - Consult.Develop.Solve.
Message 2 of 39
(8,728 Views)
Here is the source file as requested:
the sqlexec object is called Sql1.
Message 3 of 39
(8,722 Views)
Robert,
To test if the data is being posted into the MySQL database please create a new SQLExec object called "SQLSelect".
In the SQLExec, set these values:
Data Source = "DSN=pp-lookout;"
SQL = ""SELECT * FROM new_table7 LIMIT 10"
Drag the Data Members  SQLSelect.c1 to SQLSelect.c10 to a screen to see if the values are correct.
Thanks and good luck,
Mike
PS:  Folders are your friend 🙂
Message 4 of 39
(8,716 Views)
Forgot to add that you need to create a new Pushbutton to Execute the query.
Mike
Message 5 of 39
(8,712 Views)
I can only find c1-c65535 and when I do drag it, it shows 0. (corresponds to the first data member). How can I view the data in mysql workbench, because I refreshed the table in mysql workbench and it's still empty. Does the table get updated automatically?
Message 6 of 39
(8,711 Views)
Robert,
I myself have not used MySQL workbench so am not sure how that product works.
When a successful INSERT query is sent, the database should have the data almost instantly (within 1-5 seconds).
Please verify if there are any SQL errors in the Lookout Alarm Window.
Mike
Message 7 of 39
(8,707 Views)
Could it be because the odbc driver is under user DSN instead of system DSN?
Message 8 of 39
(8,703 Views)
And how does mysql recognize that this sql function from lookout is executed? Is there something else I have to do in order add this value to the column?
Message 9 of 39
(8,699 Views)
Is there an alarm in the Alarm Window whenever you execute Pb1 (the button used to execute the INSERT)?
Message Edited by Mike@Forshock on 06-17-2010 04:00 PM
Message 10 of 39
(8,699 Views)
