Lookout
DPDT Switch
 Mark Ewart wrote:This was a great tip, but I'm having trouble using it. I edit the .lks fileto put the invert sign (!) into the string, but the application doesn't readthe new file. I have edited the .lks file first (and saved it) then openedoutlook and the application.You should open .lks file you changed, instead of .l4p.This way you'll get your source code compiled.Then save the file as .l4p and you're done.The app. doesn't acknowledge the change. I havechanged graphic info, ie: size of an indicator, and the app. doesn't acknowledgeit either. Any ideas?Thanks, Mark.
Message 11 of 11
(1,065 Views)
