Lookout
EM Object - Mitsubishi Q02 PLCs
I wish to connect to six Mitsubishi Q02 PLCs.
Do I configure six EM Objects ?
Or is there another way ?
The yellow field in the EM Object marked Poll =. What is the expression that goes in here ?
What is set up at the Mitsubishi Q02 PLC end?
Can some please help ?
Better still, Can National Instruments supply a FULL worked example to follow -  For both the lookout PC side and the Mitsubishi Q02 PLC end?
An early is very much appreciated.
Thanks.
RJN723@aol.com
(5,807 Views)
Yes, you need six Mitsubishi objects. Each one connects to one PLC. Configure the object's ip address, protocol and port according to the PLC setting.
You can connect a pushbutton, or a logic value to Poll, which means the object polls the PLC when it goes high. By default, PollRate = 0:01, which means it polls the PLC every second.
Ryan Shi
(5,799 Views)
