10-18-2010 02:54 AM
I can't do this upgrade. I have a pc with Windows XP and when I try to upgrade the programm build with Lookout 4.0 to the version 5.0 or 4.5 it try to Load the program and convert it but it never finish.
Does anybody as a solution?
Thank you very much, Eder Richina
10-19-2010 12:49 AM
The source file(.lks file) should be compatible. You can open the 4.0 source file by lookout 5.0.
If it doesn't work, or it hangs, please upload your source file to ftp://ftp.ni.com/incoming. Let me try to recompile for you.
10-19-2010 01:09 AM
Ok, thank you!
I have uploaded the file in the zip folder "Lookout 4 to 5"
10-19-2010 03:13 AM
You need to install this 5.0 fix
http://joule.ni.com/nidu/cds/view/p/id/496/lang/en
10-19-2010 06:21 AM
Thank you very much!
I have copied the file of the patch in the Lookout folder and it run!
