Lookout
Upgrade from version 4.0 to version 5.0
I can't do this upgrade. I have a pc with Windows XP and when I try to upgrade the programm build with Lookout 4.0 to the version 5.0 or 4.5 it try to Load the program and convert it but it never finish.
Does anybody as a solution?
Thank you very much, Eder Richina
(6,120 Views)
The source file(.lks file) should be compatible. You can open the 4.0 source file by lookout 5.0.
If it doesn't work, or it hangs, please upload your source file to ftp://ftp.ni.com/incoming. Let me try to recompile for you.
Ryan Shi
(6,110 Views)
Ok, thank you!
I have uploaded the file in the zip folder "Lookout 4 to 5"
(6,108 Views)
You need to install this 5.0 fix
http://joule.ni.com/nidu/cds/view/p/id/496/lang/en
Ryan Shi
(6,102 Views)
Thank you very much!
I have copied the file of the patch in the Lookout folder and it run!
(6,098 Views)
