Lookout
Lookout problems with pushbuttons on a PLC5/60
I am using Lookout version 6.2 and am connecting to an Allen Bradley PLC5/60.  I am able to use a pushbutton to set and unset all outputs, but can't seem to do the same for internal coils that are set up the same way (example address: B3:1/5).  In the Data Member Configuration I have it set to logical and I've entered the correct address.  Any ideas what may be causing the internal coils to be non-responsive?
Message 1 of 1
(5,760 Views)
