Lookout
Ethernet solution
Is there a solution for Lookout 5.1 to communicate with a Ethernet network of radios, and PLC's. I am trying to use Lookout with a Ethernet radio to call other remote water tank sites with Ethernet radios and Ethernet PLC's.How would I achieve this goal.
(3,174 Views)
Hello Iceman,
One option you might want to explore is to use IPASCII if your radio would accept text commands. As far as a PLC is concerned, there are different drivers for each one. For instance you can use modbus over ethernet if the PLC is modbus compliant.
I have not done what you are trying to do before, but it is just a suggestion.
Arun V
(3,148 Views)
