Lookout
Exporting text data to MicroSoft Acess via SQLExec
I have sucessfully been able to export numberical data into a Micosoft Access database (mdb).  However I'm having issues exporting text data from a datamember.  I've been using the SQLExec object to accomplish this.
Below is the SQLExec general syntax i've implemented for text values:
"INSERT INTO test (column1) VALUES('"&(text(\\.\Process1\TEXTENTRY.value,"0")&"')
The value from the datamember TEXTENTRY will import into the mdb file, column1 if it is numeric.  Not if it is alpha-numeric.  The column is set up for text format.
However, I am able to import 'fixed' characters (not datamember text) to the database i.e:
"INSERT INTO test (column1) VALUES('hello')  the result is hello will be in column1
Please advise.
Thank you !
(6,580 Views)
Accepted by HJH72
The text() function converts the numeric to text, so you don't need it.
Try VALUE ('"&TEXTENTRY&"')
Ryan Shi
(6,569 Views)
It seems you found the solution to the problem.  Quick note though; if you are allowing users to enter text and they enter an apostrophe ('), it will error out.  Simple add a replace(textentry, "'","''") and replace single apostrophe with a double apostrophe.
Mike
Forshock - Consult.Develop.Solve.
(6,539 Views)
I want to add one line to the sqlexec that I have. This is what I want to add:
ON DUPLICATE KEY UPDATE TextSerialNo=\\.\ION7500\Textentry\TextSerialNo
to this:
"INSERT INTO dielectricpretest
(RunTime,
TextEntryModelNo,
TextEntryPartNo,
TextPO,
TextSerialNo,
TextkVARating,
TextVPrimary,
TextVSecondary,
ExpTopologyPrimary,
ExpTopologySecondary,
ExpMaterialPrimary,
ExpMaterialSecondary,
TextEntryTargetEfficiency,
TextEntryTargetNoise,
ExpHiPotPrimaryGroundPass,
ExpHiPotSecondaryToGroundPass)
VALUES
(NOW(),
'"&\\.\ION7500\Textentry\TextEntryModelNo&"',
'"&\\.\ION7500\Textentry\TextEntryPartNumber&"',
'"&\\.\ION7500\Textentry\TextPO&"',
'"&\\.\ION7500\Textentry\TextSerialNo&"',
'"&\\.\ION7500\Textentry\TextkVARating&"',
'"&\\.\ION7500\Textentry\TextVprimary&"',
'"&\\.\ION7500\Textentry\TextVSeconadry&"',
'"&\\.\ION7500\expression\ExpTopologyPrimary&"',
'"&\\.\ION7500\expression\ExpTopologySecondary&"',
'"&\\.\ION7500\expression\ExpMaterialPrimary&"',
'"&\\.\ION7500\expression\ExpMaterialSecondary&"',
'"&\\.\ION7500\Textentry\TextEntryTargetEfficiency&"',
'"&\\.\ION7500\Textentry\TextEntryTargetNoise&"',
'"&\\.\ION7500\expression\ExpHiPotPrimaryGround&"',
'"&\\.\ION7500\expression\ExpHiPotSecondaryToGround&"');
I'm not sure about the & sign and the brackets. Everytime I add it, it gives me a syntax error. Can anyone help? Thanks.
(6,296 Views)
Nevermind,
I got it:
(RunTime,
TextEntryModelNo,
TextEntryPartNo,
TextPO,TextSerialNo,
TextkVARating,
TextVPrimary,
TextVSecondary,
ExpTopologyPrimary,
ExpMaterialPrimary,
VALUES
(NOW(),
'"&\\.\ION7500\expression\ExpHiPotSecondaryToGround&"'),
ON DUPLICATE KEY UPDATE TextSerialNo='"&\\.\ION7500\Textentry\TextSerialNo&"';"
(6,284 Views)
