01-19-2005 12:43 AM
@erblock wrote:
Consider that GE is not your run-of-the-mill startup company, that this product had a huge footing before anything like Lookout existed, and that they make huge amounts of cash pushing and selling someone else's s
oftware package "Cimplicity" by a major automation software competitor.
Ed"
02-12-2005 11:51 PM
02-14-2005 10:47 AM
08-25-2005 12:54 AM - edited 08-25-2005 12:54 AM
Well the reasons are real....
Logic master does to much! If I want to view logic, toggle or force some (M) and or (Q)coils, I don't want to have someone unfamiliar with Logicmaster end up editing and ruining the PLC embedded logic, or just as bad sometimes, simple get into a "Logic Not Equal" condition. I never liked Logicmaster because of its limited security and how easily someone can corrupt logic, or just make the Logicmaster unusable for live monitoring and toggling due to mis-keying.
Logicmaster is ugly...
Logicmaster uses up a serial port...![]()
Quite honestly, I would be happy if Lookout simply had the ability to read overide status on these registers. That would be usefull in alarming abnormal conditions. For example, we routinely force off some alarms while performing manual operations, and the operator is supposed to remove the forces when he is done. I can have Lookout evaluate bits to sequence alarming, but I cannot truly know that all is as it is supposed to be unless I can grid the forces.
Now if NI gave me that ability to read the force bit...it would make sense to ME...to also have the write ability on the force bit toggle.
I'm with you on the PLC "isolation" concept, but Lookout could serve me well on many instances of force bit control and indication without putting the PLC and it's logic or programing folders at risk!
Simply...Lookout would be a better solution than Logicmaster for day to day operations. And programming/security risk at the logicmaster console could be significantly reduced.
Ed
Ahh...almost forgot... Lookout is a lot better looking and I can greatly enhance human factors performance with its beauty! ![]()
Message Edited by erblock on 08-25-2005 01:58 AM
