Lookout
How can I correct a Lookout(on laptop) alarm of not being able to open COM 2?
(5,845 Views)
More than likely you have an object(s) that are trying to use com2.  You could search the source file (.lks) to help identify those objects(s).  Then either delete the object(s) using com2 or switch to another comm. port the laptop does have.
(5,843 Views)
