Lookout
How difficult would it be to upgrade from Lookout 5.1 to 6.5?
You should be able to attach the old database in MAX, which would allow you to view the data in MAX.  Unless it can be converted, it will not show in Lookout.
Mike
Forshock - Consult.Develop.Solve.
Message 11 of 30
(3,622 Views)
The problem is that I'm using the most current MAX on a Windows 7 Machine and when I try to create a Database it crashes. How can I attach the old database using MAX? All I see is Create and Convert a Database.
I need a way to look at the old data on my Windows 7 Machine.
Thanks.
SCADA Programmer at the Coachella Valley Water District.
Message 12 of 30
(3,613 Views)
In MAX, create Citadel 4 database, and manually input the old database path so that the old database will be attached. Does it crash if you do so?
Ryan Shi
Message 13 of 30
(3,607 Views)
Yes, it crashes when I try to create a database on the new PC running Windows 7 and Lookout 6.5.
Message 14 of 30
(3,601 Views)
How big is your database?
I think you can upload it to ftp://ftp.ni.com/incoming and I will help to convert to Citadel 5 database. But if it's too huge, I will think of another way.
Ryan Shi
Message 15 of 30
(3,596 Views)
The size of the LOOKOUT 6.5\DATABASE Folder is 6.92 GB without being zipped.
Message 16 of 30
(3,586 Views)
I moved the old Lookout 5.1 Database Folder over to the new machine running Windows 7 and Lookout 6.5. I also moved over the Lookout.ini and all of the .L4P,LKS,LKA,L4T Files. When I started Lookout and finished re-compiling all the .LKS Files by opening each one up individually I looked in the Alarm Page of Lookout and it had several messages about Invalid Database Arguments. Is this normal or expected?
Message 17 of 30
(3,584 Views)
If you copy the ini file, lookout probably uses the database path as before, so you need to make sure you have the Citadel 5 database there.
In Lookout, open Options->System, here is the default database settings. You also need to check the File->Modify Process where you can set the database for this specific process instead of the default one.
To create a database, open MAX, select Historical Data->Citadel 5 Universe. Right-click My Computer, and Create/Attach database. Create the database as you like, and make sure the setting in lookout matches the database path.
Ryan Shi
Message 18 of 30
(3,550 Views)
I'm getting an Alarm on the Alarm Page the reads: Failed to log "object name" to Database invalid arguments. Could this be because the system isn't connected to the devices in the field? Everything is displaying with a red X over it because it has a communications fail. I think it might be trying to trend a value and that's why it's generating the alarm.
Thanks.
Message 19 of 30
(3,520 Views)
In the newer versions of Lookout/Citadel, it will throw this error if there is not valid data for the point being logged.  You are correct.
 Smiley Happy
Mike
Message 20 of 30
(3,516 Views)
