Lookout
How do I backup a Citadel database?
I need to backup a running citadel database. The process can not be shutdown.
(4,097 Views)
I am assuming you have the most recent version of Lookout: Version 4.5. There is an object called CitadelControl. If you do a search in the help file on "CitadelControl" you will get much information on this object.
Tommy Scharmann
(4,097 Views)
I can not get it to work. I am not sure what I am leaving out. Do you have sample code?
(4,097 Views)
