Lookout
Lookout Ethernet Communications to Field Point Modules
How do I monitor 'link' between the Lookout program and the Ethernet Field Point Module. I have tried using CommFail, but it seems to only work intermittantly.  'Link' is always present and I don't have any problems communicating to the devices.  I am just trying to come up with a way if the cable was broken (aka - loose link) , I can detect and display this in Lookout.
I am using Lookout 5.0.
Thanks for your help
Suzi
(3,076 Views)
The best approach may be to implement a "heartbeat" signal yourself -- use a digital output and toggle it on the FieldPoint, and monitor it in Lookout.  Or setup a counter and monitor that.  Search this Lookout forum for other heartbeat options in Lookout.
-Khalid
(3,055 Views)
