Lookout
Monitoring AC Voltage
This may be a moot question, but if I step down a 208Vac leg to say 6Vac and
build a simple resistor divider to sample that voltage, will the Analog module
readit? I need a 0 to X swing to monitor the Vac value. The spec. sheet doesn't
indicate dc input only, and lets face it ac is the ultimate "analog" input.
Any feedback would be great. Thanks, Mark.
(3,232 Views)
The voltage divider concept will work just fine. The question comes down to what analog module are you using? The specs on that will determine if you can read in 6 VAC.
(3,232 Views)
