Lookout
OMRON CJ1M Serial Communication
I have an OMRON CJ1M PLC.
It is not shown on the list in an OMRON Object, and the adress range I need to use (HR150.00-HR159.00) is not native for any of the listed units.
Is there an updated OMRON.cbx file to handle this?
If not, what is the best solution?
Thank you,
Robert
(5,249 Views)
If the Omron object does not support your specific PLC, you might consider an OPC server for the OMRON CJ1M Serial
http://www.opcfoundation.org/Products/ProductDetails.aspx?CM=1&RI=8346&CU=8
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(5,246 Views)
Are there any planned updates to the OMRON Driver?
(5,241 Views)
Greetings!
     At the present time, as Preston discussed you might consider an OPC server for the OMRON CJ1M Serial.  We cannot disclose any information on the plans of updating the driver or for those matter future versions of the software. What I would recommend is please take the time to fill out a product suggestion in the following link to add in the future software versions.
http://digital.ni.com/public.nsf/websearch/EDA7C01C684ACB6286256FF0000238D5?OpenDocument
Hope this helps
Thanks and Good Luck
Avi Harjani
(5,217 Views)
Got OMRON OPC server.
Will try and see how it goes.
(5,134 Views)
