Lookout
Problems with connection browser
I am using Lookout 5.1 on XCP Pro and when I try to rename an item in the list it sometime works and allows me to do it or it just stops working. Sometime the text you type appears at the bottom of the task bar.
Is this a know problem? It used to happen with W98 as well.
Derek
(3,598 Views)
Hello Derek
I have had a look into this problem for you and I am unable to reproduce this behaviour. Please could you give me exact details of the steps you are performing when this problem occurs. Also, how many items do you have in this list?
I look forward to hearing from you soon
Regards
Hannah
(3,598 Views)
Hannah
This is the system file I am using. Sometimes I can pick an item from the list in the connection browser and it works others not. Usually what I am trying to do is rename a item to correct a spelling mistake and when it goes off to scan for all links it usually crashes. It used to happen with version 5 too. This is new PC and the latest issue of 5.1 as release in August.
I would welcome your comments
Help!!
Derek
(3,598 Views)
