Home
Community
Discussion Forums
Special Interest Boards
Lookout
Topic
Lookout
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Sending DDE Execute Command using Lookout
G Harris
Member
02-23-2001
10:00 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a way to send DDE execute commands using Lookout 3.8? I would
like to be able to create a push button which would send an execute
string.
The only solution I have is to launch a Visual Basic app which performs
the DDE execute, then quits.
G. Harris
0
Kudos
Message
1
of 2
(3,166 Views)
Reply
Re: Sending DDE Execute Command using Lookout
jzizzi
Member
03-21-2001
12:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Mr. Harris,
Need a little more information, what is the process that you are sending it to? Is it over a network or local? Are you sending it to a DDE linked Lookout process?
0
Kudos
Message
2
of 2
(3,166 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
