Lookout
evidencing fluid pass throught pipe
i'm working with lookout and i would like to know if there is an example or application who can make user evidence on passing fluid through a tube to a specified direction (now i change only color to the pipe to let know that fluid is into the tube)... thanks for all and merry christmas
(3,784 Views)
Hi Roberto,
Have you tried the Animation Object?  Very simply, you can maybe move some arros/dots in the direction you want using this Object.  I must caution you however:  do NOT overuse this Object as it will start affecting the performance.
Ciao!
-Khalid
(3,781 Views)
thanks khalid.. i'll try using the animator... i only hope to finish this work till new year...
 ciao e buone feste!
(3,776 Views)
A simpler method is to use the multistate object. You make the first state true when fluid is passing then select an arrow for the graphic. Insert this object on top of the pipe. Under flowing conditions the arrow will indicate a direction. Both directions can be indicated if necessary and of course none. Black and white arrows for left/right, up/down as well as the 45 deg angles are available and can be sized as required.
Bob
(3,767 Views)
