Machine Vision
怎样读取刻度盘指针值?
各位高手,如附件图示,有一张刻度盘的图片,要怎样来读取出当前指针值?有没有相关的例程来学习学习?
Message 1 of 11
(6,398 Views)
Please try posting in english here
Translation
such as the attachment icon, there is a dial pictures, How to read out the current pointer value? There is no relevant routines to learn about learning?
Message 2 of 11
(6,334 Views)
There are many ways by which you can achive the pointer position.
1. Apply processing. like laplacian filter. Threshold. Extract the pointer position. Prepare a lookup table based on the position of the pointer.
I feel this will give you consistency
2. Find the pointer position and extract the portion with respect to pointer.
Message 3 of 11
(6,333 Views)
Check this vi
Message 4 of 11
(6,332 Views)
Vision assistant script
Message 5 of 11
(6,331 Views)
Note only one edge is found as the result. Take the edge co-ordinates to know the position.
Message 6 of 11
(6,330 Views)
Helped?any update?
Message 7 of 11
(6,318 Views)
muks ,Thank you very much!
I have checked your clock.vi.
This vi read out the pixel value of the pointer,but what i want to read out is the angle of the pointer.
Message 8 of 11
(6,288 Views)
muks,any suggestion?
Message 9 of 11
(6,233 Views)
One quick suggestion would be to make sure the successive images doesnt differ much in terms of its position and draw a line (in the centre). With respect to this you can find the angle using particle analysis. Lemme work on it a little bit for sugesting something better
Message 10 of 11
(6,228 Views)
