Machine Vision
Automatically find color
Hello all,
In a project I must check if the colors in a cable are OK.
When they start the production the systems should be in learning mode, and my problem is here.
In attach you can see a snap example. Somebody has a nice idea to automatically see the presence of a yellow part and a red part?
After that I believe it´s easy, I will put the found parts in a template and I will make a color segmentation to test the rest of the production.
Thanks in advance, best regards,
Paulo carmo
(3,318 Views)
Accepted by Carmo
Hello Carmo,
Could you please tell us what software you are using? One idea that I have is that you use edge detection for example.
Regards
(3,301 Views)
