Machine Vision
Camera ID Settings Problem
Hi guys::
              I have a problem about camera id, there are two 1394 cameras, now in my "Measurement & Automation" , they are as follows:
cam0: Point Gray Research Flea2 FL2-20S4C
cam1:TELI CSFV90BC3 V1.10
           If i do really wana to set "TELI CSFV90BC3 V1.10 " as cam0, and set "Point Gray Research Flea2 FL2-20S4C"
as cam1, what can i do?  i mean is that possible to set sepcified cam id as i want?
thanks
Message Edited by adobefree@gmail.com on 05-10-2009 03:48 AM
(4,976 Views)
It would be great if you could tell us why you want to do this. Have a look at the following articles:
Changing Interface Names of FireWire Cameras in MAX
Programmatically Finding Attached IEEE-1394 Cameras
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,963 Views)
yeh, i just mean to write the camera id fixed in program, so that the operator only need to set the camera id as i specified in test station setup introduction, instead of modify the config file
(4,960 Views)
That's OK; the first link should work for you then. As a programmer, I would recommend that you have a look at the second link and with some programming, give the operator the choice of choosing what camera he/she wants to correspond with.
Adnan Zafar
(4,956 Views)
Accepted by adobefree@gmail.com
   I know what you mean , and also prefer the second link method, but base on some certain reason, i need the first link,
any way ,thanks a lot!
(4,920 Views)
