Machine Vision
Can I use grasshopper gras-50S5M camera with NI-IMAQ 1394 ?
I am having a similar problem - I am using GRAS-03K2C, the camera is connected to the machine via a Firewire PCI Card.
I cannot see the camera appear in 'Devices & Interfaces' in MAX
Camera works fine with software provided with PGR.
I installed the camera first before installing the Vision Toolbox, could this be a possible problem?
Anyone able to help me out? :smileysad:
Alpha
Message 11 of 13
(1,156 Views)
Try going to device manager and manually changing the driver associated with the camera to the IMAQdx one.
Eric
Message 12 of 13
(1,148 Views)
Hi Eric,
Thanks it was the driver which was conflicting.
I used the 'DriverGUI' provided by PGR to switch it over from a PGR driver to a Microsoft Driver
Once using a Microsoft 1394 driver MAX could see it - and from there changing to a NI driver was straight forward  :smileyvery-happy:
Thanks!
Alpha
Message 13 of 13
(1,134 Views)
