Machine Vision
Can i convert the labview code to c or sometype else which i can program it to a CMU or microprocessor?
Hello LabView users,
I want to know how can i convert the LabView code into c or some type else (like C++ ) ?
because i want to use a microprocessor to doing image processing algorithm.
thanks
Amir
(3,388 Views)
U CANT
(3,385 Views)
There are modules for programming microprocessors and/or CMUs using LabVIEW.  That would probably be your best option.  I'm not sure if the LabVIEW is converted to C or if they found a different way to do it.
Bruce
Bruce Ammons
Ammons Engineering
(3,382 Views)
could you please introduce me some of these modules?
thanks
(3,359 Views)
You can find more info by starting at the embedded homepage:
http://www.ni.com/labview/family/embedded.htm
I would look at the Microprocessor SDK and the embedded modules for Blackfin and ARM controllers.  These might be what you are looking for.
Bruce
Bruce Ammons
Ammons Engineering
(3,344 Views)
