Machine Vision
Diameter of bottle detection using Machine Vision is it possible ?
Hello
My name is Bharath Im working on my final year college project on LABVIEW.Im focusing on Vision systems..
Though I have worked with LABVIEW for the past 1 and half years but this Vision system is not like the other LABVIEW.
Here's what I want to accomplish  I will be loading the conveyor belt with two different sized bottles i want the system to detect the diameter of the  bottle and do certain operations.. Can we do detection like that ?
Im using a USB WEBCAM ,and all these things should be continuous in real time . snapshotsw should be taken when the proximity detects the bottle at a particular point on the conveyor
Any tutorials would be helpful please post the link of the tutorials..Im in INDIA and in city Chennai..
Any one willing to help would be great ...
Ill come to your place to learn
thank you
Message Edited by Bharath kumar on 08-18-2008 09:24 AM
Message 1 of 25
(5,533 Views)
Hi Bharath,
                  What is the conveyor speed? How many bottles have you planned to inspect in a second?What is the sensor you are using?The diameter of bottle can definetly be found out using LabVIEW.
Message 2 of 25
(5,520 Views)
You can post you personal id and i can send you some pdfs and materials.
Message 3 of 25
(5,518 Views)
Greetings  Baharath,
      You actually touched a spot on me. Your application is one of the interesting applications in mechatronics engineering. muks is very subjective in asking you about your conveyor speed as this will determine whether or not you'll be able to capture "shaded " images. Keep in mind that IMAQ is very powerful tool that all you need to is to know:
  • Read about "Gray Scale" Images.
  • Read the "Edge Detection"
  • Read about "Caliper" Function
      These information can be found in "Vision Concept Manual" accompanied IMAQ. Believe it or not, you shall fininsh your project in few weeks thereafter and congraulations in advance.
     As I mentioned several times, I'm not a LABVIEW expert, I use IMAQ with VB.NET, but the functionality is the same.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 4 of 25
(5,508 Views)
Yup VBCoder is absolutely right.Getting a fundamental grip will make life very smooth bharath.Posting some images will defenitely help as well.
Message 5 of 25
(5,504 Views)
The conveyor belt comes to a halt when your bottle comes into a particular position this is picked up by the proximity sensor .
Once the conveyor belt is stopped a trigger is sent to the labview to take a picture.
This picture is then analysed to give the diameter of the object
here is a photo that will explain what im asking
The red line in the attachment is what i want to detect ..if i can do that it will do
Can some one please hand out some theories and tuts on how to proceed with machine vision and labview
Message 6 of 25
(5,499 Views)
Ok so from the picture you have posted
  • You defenitely will not be able to acheive repeatability with this lighting and background.
  • I think the material is plastic with certain reflections.You have to go for a diffused lighting.
Message 7 of 25
(5,492 Views)
  • What is the measurement accuracy u are looking at?
  • If it is the range of microns then i suggest you go for a better resolution camera.
  • Avoid color camera. Most of the application can be inspected effectively using a monochrome camera.
Message 8 of 25
(5,490 Views)
I think a accuracy of 1mm to 5mm will do
i just must be able to pickup a pepsi botlle 2 liter or 500ml so the difference is atleast 2 cm od diameter...
i just have my system right under the light so these reflections will not be there ..
Please post links of tutorials that might help me
Message 9 of 25
(5,487 Views)
Please provide more details like possible working distance  that you planned , Lens you are going to use etc
Message 10 of 25
(5,485 Views)
