Machine Vision
Get pixel coordinates of an image
I cannot find a convenient function to get x,y coordinate of a thresholded image pixel (255).
Do I have to convert the image to array and then loop through all pixels to get the coordinates?
Message 1 of 13
(6,128 Views)
Accepted by tomsze
Check bounding rectangle of particle measurements : https://zone.ni.com/reference/en-XX/help/370281AC-01/nivisionconcepts/particle_measurements/
uday
Message 2 of 13
(6,097 Views)
Oh~ I mean I want to get all pixels(255) 's X,Y
Message 3 of 13
(6,096 Views)
So you want all pixel location which has value 255?
- I don't understand why such a need, maybe if you explain full picture of what you are trying to do there could be some other means.
uday
Message 4 of 13
(6,086 Views)
Did you look at the result of IMAQ Particle Analysis VI?
Should be in the measurements from this VI.
Amit Shachaf
Message 5 of 13
(6,074 Views)
I want to develop some new algorithms base on the coordinates first.
(Sorry I kept pressing wrong the solution buttonSmiley Embarassed)
Message 6 of 13
(6,049 Views)
There is no particles 's all xy in IMAQ Particle Analysis.
Message 7 of 13
(6,042 Views)
Imaq particle analysis report returns array of binary particle measurements which includes bounding rectangle of particle.
- give an example of what you are trying to do, so that it will be easier to suggest.
uday
Message 8 of 13
(6,035 Views)
For example,I want to compute the distances from the boundaries of binary particles.
Message 9 of 13
(6,034 Views)
Particle analysis report gives the array of bounding box of particles. Once you have it you can get point to point distances between all particles.
uday
Message 10 of 13
(6,032 Views)
