Machine Vision
Hi, can someone give me some ideas on what type/brand of usb cameras are suitable for labview? i need to use it with labview vision module and image acquisition IMAQ Cheers
Hi, can someone give me some ideas on what type/brand of usb cameras are suitable for labview? i need to use it with labview vision module and image acquisition IMAQCheers
Message 1 of 10
(5,324 Views)
Can you give a breif description of your application?
Message 2 of 10
(5,313 Views)
Hi aukland,
IMAQdx 3.4 (Vision Acquisition Software 2009) and later will support USB devices that are DirectShow compliant.  Here is in DeveloperZone article with a bit more detail.
NI Adds USB Camera Support with 2009 Software
Here's a excerpt that you would probably be interested in: DirectShow is currently most popular method of supporting image transfer via the USB bus, and a number of USB device manufacturers use the DirectShow framework such as Lumenera, IDS, Point Grey, Logitech, and Creative.
I hope this helps!
Kristen H.
Message Edited by Kristen H. on 01-05-2010 10:08 AM
Message 3 of 10
(5,302 Views)
Thank you for your help 🙂 :smileyvery-happy:
Do you know what models in Logitech or Creative that have such DirectShow Framework built in? any suggestions?
Cheers
Message 4 of 10
(5,282 Views)
auckland,
If you're looking for a simple webcam rather than something industrial, I highly recommend the Logitech Webcam Pro 9000. It has great drivers (it even can make use of the UVC video drivers built into Windows or Linux, although you lose some functionality compared to Logitech's). It has a decent 2MP sensor that can be windowed to a variety of resolutions and frame rates, and a good lens for a webcam (with a true auto and manual focus controlled via software).
Eric
Message 5 of 10
(5,263 Views)
Hi all,
i have bought the Logitech Pro 9000 and successfully installed all software and it runs perfectly fun when use in normal condition. however, when i try to use Labview to acquire image from camera, it returns me error code-1074397163, also when i use vision assistant to aquire image, it says my camera is not valid. can someone give me some advice on this issue?
Many thanks!
Message 6 of 10
(5,209 Views)
auckland,
Can you give more details about what your code looks like? Perhaps a screenshot? Can you acquire from the camera in MAX? Can you run any provided examples?
Eric
Message 7 of 10
(5,206 Views)
Hi eric,
I think now i can get it going, but i would like to know where to find more examples for my USB camera image acquisition application? please advise me.
Cheers
Message 8 of 10
(5,174 Views)
auckland,
If you are using IMAQdx you can go to the Example Finder under Help and find a bunch of IMAQdx examples. Nearly all should work with your USB camera.
Eric
Message 9 of 10
(5,167 Views)
Accepted by auckland
Hi, I am using a 1.4MP USB camera with LabView. The make is IDS - a German company.
Message 10 of 10
(5,141 Views)
