Machine Vision
How can I plot the real-time intensity of a real-time image (imaq 1394)?
I've a firewire camera.
i've interfaced my camera to my pc with labview and now I display real-time image. How can I plot intensity of a region time-dependent?
Y-intensity
X-time...I would watching the real-time variaions of the intensity...
Thanks in advance
(3,551 Views)
Accepted by Artie85
The light meter example does pretty much what you want to do. It is located here:
<Program Files>\National Instruments\<LabVIEW>\examples\Vision\2. Functions\Light Meter\Light Meter Example.llb\Light Meter Example.vi
In the example, the x-axis is the iteration number, but it is easy to modify to use a graph instead of a chart and plot the time instead.
Hope that helps.
Christophe
(3,542 Views)
Thanks! I was waiting to finish my program to reply you! I'm at the and so Thank you for your advice...
But now I have a problem...
I've saved overwriting my 'Light Meter Example'(labview 7.1)...and now nothing work and I don't remember what I modified or deleted trying some changes....
I've removed and than installed my labview and its driver ecc... but this 'example.vi' is that changed by myself again...
I didn't want click on 'save'...:-(
Could you, or somebody, help me maybe posting me this .vi, please?
Thanks indeed in advance!
(3,450 Views)
(3,441 Views)
