Machine Vision
How can I process an 16-bit image?
I am using Labview 6.1 and I know that with Labview it is possible to make an image processing. I want to process (Lookup, Histogramm) an 16-bit image, how can I do this?
(3,248 Views)
You need to have the Vision toolkit. It includes routines for doing what you want. Read the help to get more information on the inputs and outputs. It is fairly straightforward.
Bruce
Bruce Ammons
Ammons Engineering
(3,248 Views)
Here is more information on IMAQ Vision, the extensive library of vision processing VIs for LabVIEW: NI Product Page: Programmable Vision Functions. This page also mentions the Vision Development Module for LabVIEW, which includes IMAQ Vision and Vision Assistant. Vision Assistant is a powerful interactive environment that allows you to quickly prototype a vision application without programming. You can even generate LabVIEW code!
Please let me know if you have any further questions on these software packages.
Dawna Putnam
(3,248 Views)
