Machine Vision
How can I use USB camera with hardware trigger?
I  use USB3.0 camera.
Usually use with software-trigger,but
In case use  hardware-trigger, how should I program about vision development?
I could not find such sample.
(4,995 Views)
Which make of USB camera are you using?
(4,973 Views)
Thank you for your reply.
I am using a camera named acA1920-40uc of Basler company.
(4,971 Views)
Accepted by sal
Hi there,
I have worked extensively on basler cameras. All the cameras come with I/O cables.
You can use the Input line for the external trigger.
Please refer the user manual for complete details.
(4,956 Views)
Can you be more specific? Which pin should I connect my output to? Can I use the NIMAX to test the triggering?
(4,629 Views)
