Machine Vision
How to tune camera's white balance with NI MAX?
I am trying to adjust the white balance of my Basler acA4600-10uc USB 3.0 camera using NI MAX. So far I have played with the Red, Green and Blue Gains on Bayer Color tab trying to find a good combinations. Pattern is "Use hardware value", pixel format Bayer. I also have tried to use Auto Calculate Gains option with different kind of white level %values. However, the result camera image is either greenish, reddish or too blue. Auto Calculate Gains does not work either.
When I use Balser's own software and driver it auto-adjusts all values and the image looks good. So, I am a bit confused how to tune the white balance with NI MAX? Is there any other options to use than Gains which can affect white balance?
Br,
Jick
(3,628 Views)
Accepted by topic author Jick
Problem solved by manually changing all values to same in MAX as Basler's own software has after auto-adjust.
Br,
Jick
(3,603 Views)
