Machine Vision
How to use imaqClampMin in vc++6.0
Hi!
I have aproblem,I can't use imaqClampMin in vc++6.0.
I also could not find imaqClampMin in nivision.h or nivision22.lib.
How can I use it!
(3,146 Views)
Accepted by djp10
How you can use it - exaplained in Help:
Technically this function declared in header nimachinevision.h (located in <Program Files>\National Instruments\Vision\Include)
Source code of this function located in NIMachineVision.c (the file in <Program Files>\National Instruments\Vision\Source\MSVC)
This is not library function.
hope it helps,
Andrey.
(3,130 Views)
