Machine Vision
I am looking for a color tri-li
near ccd image sensor, more than 800pixels/color, able to be read faster than 5000lines/sec, with small color offset. Does anyone know of anything like this? Some sensors that I have found are Sony's ILX533K and Kodak KLI-2103 but they are both too slow.
(3,710 Views)
near ccd image sensor, more than 800pixels/color, able to be read faster than 5000lines/sec, with small color offset. Does anyone know of anything like this? Some sensors that I have found are Sony's ILX533K and Kodak KLI-2103 but they are both too slow.Hello Geissbuehler,
There are a couple of line-scan cameras that meet your requirements.
- Basler L300BC (2098 pixels x 9.25 kHz line rate).
- TVI Vision (www.tvivision.com)- Prycolor is a line of cameres.
- Dalsa is another vendor that offers color line scan cameras in a variety of flavors.
In the past, I have used Graftek (www.graftek.com) for spec'ing out cameras (especially the higher end digital cameras).
- Ask for Robert Eastlund.
(3,710 Views)
near ccd image sensor, more than 800pixels/color, able to be read faster than 5000lines/sec, with small color offset. Does anyone know of anything like this? Some sensors that I have found are Sony's ILX533K and Kodak KLI-2103 but they are both too slow.Thank you for your quick reply. However, the cameras that you mentioned are either not tri-linear, at least as far as i understand the term (the TVIs and the Dalsas use prisms to separate colors, which is much more expensive), or the color offset is too large (as is the case with the Basler 112microns). Also, these are all cameras, not sensors. I just need the chip with the ccd pixels, not the camera housing and the lens.
(3,710 Views)
