Machine Vision
I have recently started using the IMAQ add-ons in Labview 6i.
Does anyone know if I can easily (and if so, how?) convert a 16bit image to RGB format (or vise versa) without re-opening it?
Dan
(3,629 Views)
Dan,
I believe you are looking for "IMAQ Cast Image" under Image Management, which will convert from one image format to another. The help information should be enough to get you on your way.
Bruce
Bruce Ammons
Ammons Engineering
(3,629 Views)
Bruce,
I knew it would be simple! Thanks, exactly what I was after.
Dan
(3,629 Views)
